tezzietron
- Joined
- Aug 21, 2005
- 17
Have a leak on the middle carb port side. Have already marineteked the bb's on all bowls, the bowls on all carbs are slightly warped, but not leaking. Motor runs smooth at all speeds.<br /><br />Gas is puddling in the cavity made by the ribs on the throttle plate assmbly on top of the middle carb plateau, and is weeping out the upper hole in the bottom carb flange (on the left side, looking at the motor from the front).<br /><br />There were numerous scratches in the throttle plate assmbly where the carb face seals seat - I lapped all three carb mounts, no more scratches and replaced the seals. Replaced the manifold seal when I reinstalled the works.<br /><br />I've tried all three port carbs, and one of the starboard carbs in that spot - the leak doesn't move. <br /><br />Appears to only leak at idle, at mid to high speed it appears to stop.<br /><br />At wits end on this one - beginning to think I might have a crack in the throttle plate assembly - any ideas ?<br /><br />Steve T
