In 22 years this motor has never had a repair, with the exception of replacing the fuel lines because of alcohol in the fuel in later years. But after a month fishing in Ontario, at full throttle it would seem to jump out of gear (shift dog?). If I stayed under full throttle it wouldn't do it. Here's my question, would you fix this engine, or replace it? Engine compression is good 140 over 135. I'd like to keep the cost down, but a new engine isn't out of the question since this one has plenty of miles on it. Is it possible to find a newer 50hp two stroke Johnson with a tiller handle? I've looked and can't find one with a tiller. I want the most hp possible for the least amount of weight. 50hp is the max that my boat is rated for, as that was the largest tiller motor made in 1983. I contacted the boat manufacture, and they will not certify it for a higher horsepower. Suggestions?
