Johnson lower unit repair or replacement
newport
Last Friday I sheared off the propeller shaft and propeller on my Johnson 150hp outboard. I believe the shaft fatigued because I was in 30+ ft of water and no evidence of anything visible that I could have hit. ..still trying to figure it out,. My question is, the marina mechanic says I should replace the complete lower unit vice replace the shaft because salt water got into the lower unit and will pit the gears immediately.There is a significant cost difference that is having me question the need for complete replacement.
Joe Reeves
Re: Johnson lower unit repair or replacement
A competent technician would first recommend that the lower unit be torn down completely. After which the parts would be cleaned and inspected and a accurate estimate could be made.<br /><br />At that point, you could decide which route you would want to travel... repair or replace.<br /><br />What is the model number of your engine. If the propshaft is not available on this website, I have a few propshafts left in my remaining stock that I could discount, but try this site first.
newport
Thanks Captain for the advise. The engine is a RH turning Johnson 150 HP 1992 Silver Star Series V-6 outboard
newport
My 1992 150 HP Johnson Model # is either J150NXENC or J150EXENC... not sure which one is the RH. Thanks John
