FishMagnet
- Joined
- Mar 19, 2005
- 79
Last time I took my old boat out on the lake she was running great. I set her up in the driveway yesterday to run it for awhile and check the timing. After a VERY hard start it started running rough, better after a long warmup. At random intervals though it would "miss" sometimes enough to kill the motor. I ended up taking the plugs out and they were quite black and grungy.<br /><br />The oil/gas is mixed correctly and the low and high speed setting have been set using the J.Reeves method. <br /><br />I'm hoping for any suggestions on where to start looking. I do use the boat mostly for fishing, should I think about switching to J6C Champions? (I'm currently using the recommended J4c)<br /><br />Thanks,<br /><br />Matt<br /><br />P.S. Paul, if you're reading this. The timing was on the very right side of the | | mark. In case you're curious.
