1997 Johnson 150 losing fire
Seasport
Re: 1997 Johnson 150 losing fire
Does sound like you have a dodgy powerpack but hard to verify until you swap it out. The sensor is cheaper but chances are if you tap directly on the powerpack and it fixes the problem, then it is most likely the powerpack.<br /><br />Have you checked the connectors going to the powerpack, i.e. unplugged and replugged them? Intermittent connections can change with temp as well as things expand and contract.
90srtatos
yeah seasport i have plugged and unplugged a dozen time coils off and coils on , power pack off and power pack on the plugs on the power pack are good and tight . thanks guys for the help and input , you know this thing is really a pain in the a$$ or in the $$$$$$ , think i just buy the power pack . thanks guys ill let you know what happens. thanks again
clanton
Send me a bank draft, and I will drive over Monday, with tools and test equipment.
90srtatos
YEAH THE MOPNET IS ON ITS WAY!!!!!!!!!!!!!HAHAHAHAHAHAHAHAHAHAHAHAH
limacina
Aftger reading this post, I found a positive point for my gas guzzling twin outboards. Parts exchange!!<br />Best of luck and be sure to follow up with your findings.
90srtatos
CLANTON ,IN YOUR OUN OPINION DO YOU THINK THE POWER PACK IS THE PROBLEM . OOOPPSS sorry for the caps , i want your opinion before i buy the pack!!!!
90srtatos
clanton what do you think power pack or not ???????????????????
90srtatos
so can i get anymore input on this guy?
90srtatos
any help will be very helpful and thanks for the info so far !!!!!!!
clanton
I have been to Alabama, just walk in the door, and Im ready for bed.
90srtatos
ok i get up with u tommorrow
90srtatos
Can i get some more input on this thing !!!!!!!!!!!!i need a 1997 johnson 150 expert to help me out. thanks in advance, chris
sikpnter
90stratos! If it makes you feel any better, I'm sure it doesn't! but I am having the EXACT same problem, I mean to a tee with my 96 150 so I'm keeping a eye on this one and If you figure it out will you please keep postin. Good luck
Seasport
Chris. Chances are it's your powerpack. These are prone to causing problems on these motors. The standard test for the powerpack is to check that you are getting output voltage on each ignition coli primary lead as you crank the motor. You need to connect a 10 ohm 10 watt resistor load across each lead as you do the test and you should read more than 100V peak voltage output. This will tell you if you're not getting a spark signal to any coil. However, there's no real way to test for powerpack internal electronics faults which could lead to intermittent faulty behaviour. You really need to swap out the powerpack.<br /><br />If it's not your powerpack it could be the optical sensor which is faulty. However, since you can fix the problem by tapping around the powerpack it suggests the problem is in the powerpack but you won't know for sure until you put a new one in!<br /><br />There is a good ignition system troubleshooting guide which you can download from www.rapair.com if you want to read more about the ignition system on these motors.
90srtatos
can u peck your coils sikpnter and you start getting fire again , if so i will let you know if its a power pack, cause i got one ordered online for 133.67 here is my email address and i will tell you where from, email me what kinda of trouble u r having and ill let you know if it fixes it you can get one cheap too the local dealer want $235and $175 and $150 but i found 1 for like i said 133.67email add. jcadkins@bellsouth.net
90srtatos
and i want to personally thank you guys for the input and your time . thanks again,,,,chris
90srtatos
i got the power pack today and put in on , i put the muffs on it and started it in the yard seems to have cured my problem , but i want really know till tommorrow im going fishing ,and i ll let you know for sure if the pack fixed it . thanks guy for all the help and posts , chris
90srtatos
the power pack was the problem for sure run great today ,,,,, thanks guys for the help and the input , i want to thank you guys for streering me in the right direction , thanks guys a million !!!!!!!!!!!!!!!!!!!! Chris
