Lifting a 120 hp
Tom Scully
There is no lifting ring on the engine.<br />What would be the best place to lift it from?<br />I am a leary about lifting from the flywheel.
Dhadley
Re: Lifting a 120 hp
The lifting ring attaches to the flywheel.
Tom Scully
My local dealer wants 70 bucks for the lifting ring plus 39 bucks for "eyebolts"!<br />I haven't had any luck searching online for one.<br />Can I just screw in three eyebolts and lift it from them without causing any damage to the crankshaft?<br />I will make sure to balance the load between the three of them evenly.
umblecumbuz
Is there any reason why you can't lift it by making a webbing harness around the motor?<br /><br />- Save a few bucks if you can.
MarkHPCA
If you do use webbing be cauefull. I had a motor fall, nearly taking off my buddies leg, when the teeth on the flywheel cut through the webbing.
noelm
Hi<br /> when I swapped my 120's for new motors I just made up a flat lifting ring and bolted it to a spare 3/8 bolt hole tapped into the motor casting, not really sure what it was for but it never had a bolt in it from new
Dhadley
Thats a boss and hole thats part of the power steering set up on a V6 and V8 looper. They all use some common casting molds.<br /><br />The best way is to use a lifting ring thats bolted to the 3 holes in the flywheel. That lifts it up straight and centered. Lifting it off center on a bolt may cause it to shear off.
Walker
Don't know whether its right or wrong but I have lifted a bunch of big motors by pulling the starter off and attaching a chain to a starter bolt and a head bolt on the diagonal side. Hook the chain in the center and lift.
Tom Scully
Thanks for all the input guys.<br />I am going to make a "lifting ring" out of an old flywheel puller I have. <br />I will bolt it to the three holes in the flywheel and use a heavy eyebolt thru the center of the puller, where the "drive bolt" usaully goes.
Dhadley
That'll work. Thats basically what the OMC / BRP lift ring is.
