denislajoie
Thread starter- Joined
- May 28, 2005
- 62
I have an old Johnson Super Sea Horse 40 hp, manual shift,cant tell y ou much more cause the transom plate was changed; its white, has a wierd handle on the rear of the engine and the carb has a glass ball underneath it, pictures are coming, anyway, i took out a screw on the bottom right of the lower unit thinking it was the drain plug, when i did, something inside moved, stuck it back in and ever since, it is stuck in forward, is there more than one place that pin can go, it is about 1.5 in long and only has thread in the first 1/4 near the head, if i need to remove the lower unit can i just split it in half by removing the 6 or 8 flat headed screws that go all arount the unit or is something else gonna pop out at me... anything helps...
