Guage Question
D
DJ
Guest
I just purchased a "seventies" 50 HP Johnson attached to a Boston Whaler 15' Super Sport.<br /><br />The engine info. is: <br /><br />Mod# 50ESL75B<br /><br />Serial# E4265230<br /><br />My questions are:<br /><br />1. I assuime this engine has a charging system?<br /><br />2. What pole do I set the tachometer to?<br /><br />3. Can I install a water pressure guage. If so, HOW?
MCM
Re: Guage Question
DJ, same motor I have, 1975 50hp. For the tach you would want to set it on setting 6, (12 pole = 6 pulse), engine is loop charged also. As to the water pressure gauge I'm not sure how that would be done.
bubbakat
Re: Guage Question
DJ this may be a dumb question. Is that a V4 engine? If it is I have some pictures that will show you where to locate it. If its a 3 cyl I might be able to help there to.
MCM
Re: Guage Question
It's a 2 cylinder ;)
Paul Moir
Re: Guage Question
Ought to have a 6 amp stator (charging system). The rectifier is the round thing with the three wires just about the junction block & power pack.
mikeyzx2
Re: Guage Question
I'm taking a stab at it, but could the WP gauge be tapped into the motor like the telltale's are?
D
DJ
Guest
Re: Guage Question
Thanks all.<br /><br />It's a 2 lunger (2-cyl.)<br /><br />1. Any ideas on water pressure?<br /><br />2. Where do I tap into the control box for tach? It DOES NOT have the OMC handy "plug in".
MCM
Re: Guage Question
DJ,<br /><br />Depending on the control box, you may have to open the box, there should be a gray wire which is the send wire, if your tach has 3 wires one wire will go to the gray, one to the pos. & one to the ground terminal on the start switch.<br /><br />What type of c/box is it and what brand of tach?
