Evinrude Identification Confusion
Wiggy
I've just brought a Evinrude outboard and parts motor cheap. The guy that sold it to me said that the motor with serial number 20202R B30510 is a 25hp (has 25hp hood). This I found out to be a 1972 20hp.<br /><br />The parts motor has serial B009522 model E20BFCNB. This I found out to be 1982 20hp. <br /><br />The working motor has a dark blue shaft and the parts motor a light blue shaft. <br /><br />My question is, are my findings correct? Is this motor a 25hp?
MCM
Re: Evinrude Identification Confusion
Wiggy,<br /><br />The model# 20202R matches with a 1972 20hp Evinrude.<br /><br />The model# E20BFCNB would indicate a 1982 20hp 'Rude<br /><br />No 25hp there!
Wiggy
That's weird, as the internals are almost exactly the same.<br /><br />The choke handle and stop button look older on the '25hp' but the carb set-up has an extra rod from choke to throttle on the 20hp. They've also got different transoms, not drastically, but different.<br /><br />Weird!
MCM
You don't have a 25hp motor, both are 20hp motors, someone probably replaced the cover at some point. Also there should be some differences, theres 10 years seperating them. If you want to find out what parts are interchangeable you can go to this site,<br /><br /> http://epc.brp.com/default.aspx?brands=ej&lang=E <br /><br />Use the advanced search feature to cross reference part #'s
Wiggy
Firstly the website has just the 25hp both years and even they don't work?<br /><br />The later models work fine?<br /><br />Any ideas, other sites?
MCM
Wiggy, that is very wierd :rolleyes: , both model #'s indicate 20hp motors. Click on this site then click on Modellguide at top right corner, Click here,
MCM
Wiggy, that is very wierd :rolleyes: , both model #'s indicate 20hp motors. Click on this site then click on Modellguide at top right corner, you can find the years of motors there. Look for an alumunum freeze plug on the top of both motors, the model# should also be located there. Post back what you find.
papasage
some one could have changed thr power head .i changed a 50 hp 1973 head to a 1974 foot . those power heads was the same except the 1973 50 was a eletric shift . the 1974 was a manul shift
MCM
papasage I agree but OMC J/E doesn't seem to acknowledge a 20hp motor for those years yet both model#'s would indicate a 20hp motor???
MCM
ishopmarine.com, click on parts lists at the top of the page then find your motor.
