20 hp Evinrude- no model # plate
Dougs50
Sirs, I just purchased a used boat and motor. The boat is a 1992 Bass Tracker Aluminum boat. The motor on the boat is an Evinrude 20 hp manual start and tiller control. <br /><br />The Motor also has a decal of Evinrude plus a decal for Tracker. This looks to be a matched setup for boat and motor. My problem is the model number tag is missing. So I’m not sure of the model year. Is there another set of numbers that would associate with the year made?<br /><br />I found some other numbers on the motor that may help.<br /><br />Facing the motor from the front. There is a metal plug on the back left of the motor block with the numbers G622206. Another set of numbers on the left side of the block(on the block itself not a plug). 335636. And the other set is on center back on the bottom. This is a circle of numbers 1-12 with the number 89 in the center. <br /><br />Thanks for any help you may be able to give me. I’ll need a prop for this motor.
MCM
Re: 20 hp Evinrude- no model # plate
Check on the top of the block for an aluminum freeze plug, the model# and serial# should be located there.
Dougs50
Thanks mike. i'll look there. Have a good turkey day.
MCM
You do the same :D
Dougs50
Mikt, The freeze plug on this motor is on the left side facing from the front of motor with the number G2622208(I thought the last number was a 6 before).<br />Some other numbers I found while cleaning the carb. Fuel pump has a part number of 433386, 10-H-P Mexico.<br />Number on carb mx336527. Hope someone can help. I want to get the right manual and prop.
MCM
That first set of #'s might be the serial#, we need the model#, in order to find the year of the motor etc. It should be located in the same spot as the serial#
Dougs50
Ok thanks. i'll keep looking. My next order of business is to remove the prop. Hopefully there are some OEM numbers to go by. At least get me in the ball park.
Dougs50
do you know of a web site to cross reference parts numbers such as the fuel pump/ carb. i've found some fuel pump numbers that are close to the one I have 433386. only the first 2 numbers match. the (43-----)Looks like I'm getting closer.
MCM
The problem with that is alot of parts aren't specific to one motor or year. They may have been used on several hp motors over a period of several years. If you find that plug it will have both the model# and serial#.
Paul Moir
The serial number seems to indicate very early 90s. Probably 1990.
