I just bought this manual 35. It starts on the 3rd pull everytime. However, I must put the throttle at high rev, until it warms. When it has run recently, it starts on one compression stroke.The problem is when idling, while picking up/putting out decoys. It has a tendency to either sputter and stall, or speed up in rpm's, on it's own!!! If I wiggle the throttle handle, just enough, it will continue to run ok. I cannot turn the handle ever to complete idle or it will stall. I must keep it around the "start" spot on the handle.
Does this motor need a carb rebuild to correct this situation?
