I have a 1986 110 hp 4cyl. evinrude vro. model#e11omlcdc. Serial# r1308421. I bought this off a friend of mine who took the thermostats out because it wasn't pumping water. The thermostats were in pretty bad shape. I got it running and it pumps water good without the thermostats in. My winter project is making this motor reliable and ready to go for the spring. I am putting on a new non vro fuel pump, water pump, and thermostats. The guy said I can run it without the thermostats, but I fear on the cool nj mornings that this might foul the spark plugs on the cold 2 stroke engine. I noticed in the service manual that it suggests changing the thermostats when the power head is removed. I can't believe you have to remove the power head to change thermostats. But as I could remove the empty therm. housing. I am having a real hard time trying to install the housing with the therm. parts in it. My question is: Do I have to remove the power head to do this thermostat replacement? If no, how do I go about it. Also I could use some tips on doing a water pump assembly replacement on this motor because I never did it before.
