ericgodlieb
Thread starter- Joined
- Feb 1, 2006
- 8
Hi all,<br />I have a 33hp jonhson. When i bought it, it was starting/running oke, but only the impeller was broken so i shut it off and replaced the impeller. When busy with the lower unit i also noticed that there was water inside the lower gearcase and replaced all seals. After i put the engine together again it was running for a few seconds and after that is not running anymore.<br />The battery is full, fuel is oke, carb is clean, fuelpump oke, spark's oke (nice bleu spark, timing oke, both sparks getting fuel. The only thing i notice is that the lower cilinder spark is very wet. So what do i miss here?? Maybe the temp outside, it's here now + 3 degrees celcius???
