I have recently acquired a 1983 15hp johnson .<br />now i have changed the impeller, plugs ect to be safe and ready for use but have noticed that when i run it in barrel of water or with muffs on in gear, if i try to put it into nuetral or from nuetral into either forward or reverse i have difficulty it does not engage.(breathes) when i turn the prop slightly manually it will engage ok.<br />have i possibly reconnected the gear selector rod incorrectly when refitting after changing the impeller.<br />i had the gear lever in forward to help me do this.<br />baffled!!<br /><br />thanks<br />Alex
