My problem is as follow, these motors were sitting over 5 years. I have replaced fuel pumps and all hoses including the primer balls. I have also rebuilt the carbs (6 per motor),ajusted the throtle plates and timing, changed plugs and wires. I have also cleaned all electrical connections and checked for good connections. I have also checked the flywheel magnets for condition and fixture.<br />My problem is the port motor will not pass 1500 rpm and the starboard will not go past 2800-3000 rpm. In addition to the above both motors have new water pumps and thermostats, I have temp. guages and a working warning system. Both motors do not overheat and pump water just fine. Both motors start easy and idle at about 900-1000 out of the water. Can any one give me some advise before taking it to a mechanic.
