1991 40 hp Evinrude (tiller) Tilt & Trim
fenwick
I have a 1991 Evinrude 40hp tiller.The problem <br /> I'm having is when I tilt the motor down I get<br /> a popping sound.After I bottom out the motor <br /> and keep the tilt button depressed,I will do <br /> this a few times.Then I will do the same by <br /> tilting the motor up and keeping the button<br /> depressed a few times as well.After I've done<br /> this the popping sound will disappear.But It <br /> keeps coming back after awhile. :confused: <br /> I've checked the fluid level and it is topped<br /> off.Does anybody have any clue as to what this<br /> might be?
muskrat
Re: 1991 40 hp Evinrude (tiller) Tilt & Trim
sounds like the tilt pins are starting to bind,remove them clean & grease them & reinstall..
woodduck17
Let me know if this works for you. I have a 89 40hp that does the same thing. I tried greasing everything on mine and it didn't help. If it works on yours I'll try mine again.
fenwick
muskrat,<br /> I checked out a service manual from the<br /> library but it is really vague.How do <br /> you take out the tilt pin? Is it the<br /> pin that is on the top of the trim unit?<br /> Could you give me a few pointers! It <br /> would be much appreciated :D
OBJ
You'll have to raise the engine all the way up to access the pin. It's the pin that holds the ram to the engine. If you remove it, you will have to support the engine in the up position.<br /><br />Have you shot some grease into the two grease fittings that are on the top front of the transom brackets?
