One more try
dorkhead
Re: One more try
If your trying to help just answer the first question --and only IF you can You guys brought all this on not me. BTW I called Bombardier and they do have a rebuild kit for that motor. I talked to a tech online and he told me that. I just should have gone there first and not put it out to a bunch of yahoos. Someone took the first shot at me by accusing me of throwing money at a problem and telling me to (buy the manual).Well excuse me for asking first. Asking a question is not exactly throwing money. That came from other research from other people on this forum who told me it can be nothing else but the pump. Grow up Case closed No need to reply
OBJ
Re: One more try
Boatwad, if I gave you wrong info on the pump, I do apologize for that. The last time I tried getting a rebuild kit for a pump, the numbers superceded to the whole pump which means the kits aren't available from BRP any longer. If that makes me a "yahoo"....OK....I'm a yahoo.
DHPMARINE
Re: One more try
Damned if you do or don't.I'm not sure where the moons are tonight.But I sure expect lots of meteor showers on both coasts.We have to STOP taking these shots at newbies with so little posts.They know so much more than us,and where else to get the right answers.<br /><br />We have to listen to them.<br /><br /><br />DHP<br /><br />Yeah right
OBJ
Re: One more try
LOL @ DHP! Yeah your probably right DHP. With the amount of post's we get a year just on this forum, it's gonna happen on occasion I guess.<br /><br />Ya' know though....we could rename the forum to "The Yahoo Zone"....if you need help with a John/Rude....just hollar "YAAAAAAAAAAAAAAHOOOOOOOOOOOOOOOOO" :)
Ranger01
Re: One more try
Well if you guys are among the yahoos on this board then i must say i am proud to be a yahoo with you guys!
ob
Re: One more try
I don't believe the rebuild kits contain any parts for rebuilding the oil half of the VRO/OMS if it makes any difference.A common failure of the VRO pumps were failed seal between fuel and oil half causing oil rich(smoky)initial startup.
OBJ
Re: One more try
Your right ob, they didn't. One thing for sure, I'm on the horn tomorrow to find out about these mysterious rebuild kits for the pumps....... :) :)
OBJ
Re: One more try
Just did a search for his previous thread on the same engine. Seems the engine was surging at around 3500rpms but would take off if the primer bulb was squeezed. He also asked about the rebuild kit there also. Didn't see anywhere in those posts, on this forum at least, where anyone said it could only be the pump. Here's the link if anyone is interested.<br /><br /> http://forums.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=28;t=039074#000000
Ranger01
Re: One more try
i also read that post and agree, it was not mentioned.
ob
Re: One more try
Thanks for the link OBJ.I would be surprised if that late model had a failing OMS pump already but ,who knows.Don't know what kind of hours are on it.I do know ,that if the engine picks up when squeezing the fuel primer ball that a failing fuel pump is but one of the posibilities.A fuel leak upstream of the pump inlet can produce the same symptom.Also a leaking pulse hose or faulty limiter.
MCM
Re: One more try
Yup, I read that one first then responded to this one, didn't care much for the attitude in that one, guess it didn't improve with time :rolleyes: <br /><br />He doesn't seem to be having much trouble getting responses in this one though :D
Ranger01
Re: One more try
While he didnt have problems getting answers on ths post, i imagine that not to many of them helped answer his question. Though i suppose that perhaps he may have learned how to get answers from everyone through the dealings on this post. If he uses it that's another question. At least it gave all of us somthing to do this evening.
ob
Re: One more try
Originally posted by Ranger01:<br /> While he didnt have problems getting answers on ths post, i imagine that not to many of them helped answer his question. Though i suppose that perhaps he may have learned how to get answers from everyone through the dealings on this post. If he uses it that's another question. At least it gave all of us somthing to do this evening.
Good brain exercise if nothing else.Any one else know of any other posibilities that pumping the primer ball while underway would rectify? :D
Walker
Re: One more try
I can think of 2 without trying very hard. A leak in the pulse hose and too small supply hose.
ob
Re: One more try
Originally posted by Walker:<br /> I can think of 2 without trying very hard. A leak in the pulse hose and too small supply hose.
Pulse hose and limiter have already been chosen Walker. :D But the too small of fuel line gets full credit. :D
Walker
Re: One more try
Boatwad/Buttwad, Full credit/no credit, its all the same to me :cool:
