rob 669
my 1970 60 hp johnson idles fine but has fits when i throttle up spits sputters and misses real bad with no speed at all my question is could it be the fuel pump or someting electrical? i had just done a carb cleaning and a tune up on the thing.but didnt help things
JB
Re: ?
Hi, Rob.<br /><br />Welcome to iboats. :) <br /><br />This is the wrong forum for your question. You want the Johnson and Evinrude outboard troubles and repair Forum.<br /><br />I will move this there for you. Lots of help there. :)
Re: ?
did u remove the carb soak it overnight, blow out all the ventricals w/ compressed air, run a small wire thru the high speed ventrical to make sure it was clear? have you check all your hoses for leaks? is you primer bulb arrow pointing toward the engine? have you check spark, compression,? what are the comdition of you coils, cracked , leaking? post model # on transom bracket, just a few questions for starters. welcome to i boats. i'm running a'55 and a '73 rude.
rob 669
Re: ?
No i didnt soak the carbs overnight but i did clean out all the crevaces and ventricals. i also put new hoses on and cleaned the points real good the compression was within a couple pounds of normal on one and perfect on the other. thanks for your reply i really can use the help.season is coming up quick.
Solittle
Re: ?
The crud that needs to get cleaned out is in the small internal passages and jets. Surface cleaning will not do it. You need to go back through them and install new carb kits.
rob 669
Re: ?
so do i redo all three or just the high end carb? the thing idles fine its just when i throttle up?
rob 669
Re: ?
Originally posted by rob 669:<br /> No i didnt soak the carbs overnight but i did clean out all the crevaces and ventricals. i also put new hoses on and cleaned the points real good the compression was within a couple pounds of normal on one and perfect on the other. thanks for your reply i really can use the help.season is coming up quick.
the model #is 60es-70d
