Originally posted by findre:<br />
Originally posted by Dhadley:<br /> Yep, they're set up like V6's. You probably won't see any difference between the 275 and the 300. At 5200 youre not getting anywhere the capability of a 300. 5800 is much closer but you've got a ways to go. The big problem is that the Sea Drives are hard to move up. Not like an outboard unfortunately.<br /><br />What "other stuff" did they fix? What spark plugs are you using?
Both engines have all new electronics, timer bases, coils, wires, Champion plugs, carbs are shiney clean, (2) 2140 Malloy fuel pumps to prime and pump with low pressure warning, VRO is disconnected and capped VERY WELL, fuel lines are fitted with brass T's in place of plastic BS in a better flowing format.<br />What RPM should I be at? At 5800 they sound good, but I cant see turning the blenders up much more. I was always afraid of them going POP.
