Re: 1992 Johnson Evinrude 120 hp
These opinions may help the discussion along:<br /><br />RetNav.... I try not to ever criticize a fellow mechanic; however your mechanic's suggestion about the thermostats does raise some questions.<br />(Thermostat Purpose)<br />Many engines are considered high performance engines and demand a thermostat(s), and many smaller hp engines also require a thermostat for the following reason. The pistons actually distort/twist off round when running. The thermostat is required to keep the outer wall surrounding the steel cylinder, and the cylinder wall itself at a temperature to compensate for the distortion.<br />With the thermostat removed, the difference in temperature between the inside the cylinder and the water jacket quickly reaches a point whereas (in effect) you have a oblong piston running up and down a round cylinder. Bottom line is without the thermostat, the piston and cylinder wall could be damaged in a short period of time.<br />--------------------<br />ReevesJ32@aol.com<br />30+ Years With OMC -- Joe Reeves speaking of a 1990 200HP Looper without t-stats <br /><br /><br />The t-stats on that motor are part of the pressure control, it may be one side is stuck open, that motor should idle about 150-160*.at idle it uses water pressure to hold the diaphragms down to keep the stat seated, when the water control valve opens, its connected to the advance lever, it allows the stats to move off the seats as needed. Not only does that engine need lots of water pressure if you dont have the stats it runs nasty and its possible to fry the water cooled regulator. -- <br />Rodbolt Speaking of 1991 120HP Looper <br /><br />It may not idle smoothly, it would have poor throttle response from idle, it could lead to cold seizing, and piston damage. At wide open throttle you wouldnt know the difference. -- <br />RJohnson Speaking of 1992 120HP Looper without t-stats
