I recently replaced the rope on a Johnson 9.9. The problem is the pull is not smooth and the rope is starting to fray again. The spring is engaged by the spool and the washer is under the spring on the bolt. It seems that the rope is not in the correct position when it comes off the spool when it is pulled. The rope is contacting the metal and the plastic spool and is binding. The rope does ride under the plastic prawl. Does anyone know what could be causing this grief.
