Carb Jets
Bill Mattor
How would I check the carb jets visually to make sure they are good? They look ok but I don't know what I'm looking at!<br /> Also I have the low speed running fine. Is there anyway to set the high speed in a test barrel?
Dhadley
Re: Carb Jets
Jets really dont wear. If someone has drilled it and didnt do it right, throw it away. Generally if it looks good and clean then it's OK.<br /><br />Setting high speed jets in a barrel is kinda difficult but it really depends on what motor you're working on. And the size of the barrel.
