I finally removed the old t-stats from my Johnson 115hp V4 (crossflow)and it had a lot of "calcium deposit like" grit inside.<br /><br />I'd like to do two things before installing the new t-stat kit I have.<br /><br />1) I would like to run the motor without the t-stats just long enough to see if the temp alarm still goes off (original problem see previous posts). <br /><br />When putting the assembly back together without the t-stats, Do I still have to put the white plastic valves and springs back in?<br /><br /><br />2) I would also like to run some CLR through the cooling system in an attempt to clean out some of the deposits BEFORE i put the new t-stats in so they don't get mucked up. <br /><br />Any thoughts on this?
