I am leaking gear oil at the prop shaft seal that you see when you remove the prop and the washer it seats against.( Im pretty sure its coming from here but dont know if there are other seals deep inside the housing) Whats the best way to get this thing out? I removed four 10mm bolts from deep inside the shaft housing but couldnt remove the entire assembly. I dont want to force anything,but would like to replace all the seals. Do I have to drop the entire lower unit to do this. I bought a water pump kit(impeller and seals) 2 years ago and dont want to mess with that end if I dont have to! <br />Any advice would be appreciated! Thanks!
