no plate with model # any other way to determine year???
skitz999
no plate...<br />dont know waht a freeze plug is...<br />need to know where to find model # and year???<br />johnson 9.9 probably sometime early 80's just not sure....<br />thanks for any advice....
Cricket Too
Re: no plate with model # any other way to determine year???
skitz...A freeze plug is a small round, maybe silver, plug in the block.
ezeke
Look for a round, convex aluminum seal around the top or side of the engine block. <br /><br />If it has two sets of numbers, the first is the model number. If it has only one set, it is the serial #.
skitz999
can i find out any info from the serial #???
ezeke
You might get lucky, post it here.
skitz999
is this possibly the serial# H7844332
boat_crazee
Had similar problem. I used this Bombardier site to get part numbers for various models and years. With a few part numbers (like the transom brackets), I was able to sort thru the website and find the year of my motor. The model is tougher, but at least if you find the year, the models are then identified. Good luck.<br /><br /> http://epc.brp.com/default.aspx?brands=ej&lang=E
ezeke
web page <br /><br />Seems like we have seen that SN from Philly before.<br /><br /> web page<br /><br />Here he thought it was 1985.
skitz999
thanks for the advice guys you guys are great...
