Johnson 8hp Outboard. What year/model?
boat_crazee
Hello,<br /><br />I have a Johnson 8hp outboard, (2 stroke, 2 cyl), but not sure of year and model. The unit is WHITE and I did find the number B8444842 on a small plate in the engine compartment. I was not able to locate any model type numbers in the transom bracket area. This appears to be a short shaft model. Also, there's a small decal on the engine cover that reads "TIDERUNNER". Not sure what that means, but it sounds good.<br /><br />Any help to identify this motor would be appreciated. Thanks in advance.
OBJ
Re: Johnson 8hp Outboard. What year/model?
That number don't compute with any Johnson crazee.....look on the engine block for a large welch plug. Model and Serial number should be there.
boat_crazee
OK Thanks for the reply. All the great info in other postings should also help in tracking down the elusive J8???? number.
boat_crazee
Found what I needed. It's a J8RESR. Thanks
