rattlin spot1
- Joined
- Jan 18, 2004
- 15
I am posting this for a friend who is having problems with his 1987 xp 200 engine.The engine runs as it should until it gets to approx.4000 rpm's then it starts to surge or lose power.I beleive that its losing losing a cylinder when this happens.The engine has had the water pump,flywheel,sparkplugs and the electric fuelpump replaced.The manuel fuel pump and the vro were dissconnected several years ago.The carbs have been cleaned and kits installed.The engine has been to 2 shops and they cannot fix the problem.The last guy said that he has this problem before with engines of this year model and could not repair them.We have run it on a portable gas tank and the problem is still there.We have installed a timing light on each plug wire and the spark looks to be okay while the surging is present.The power packs have been changed out with known good ones and the problem is still there.The coils have been checked and show no problems.Nobody has been able to isolate the problem to one cylinder.Compression is 125 to 130lbs on all cylinders.If anyone can help we would be very grateful.Thanks.
