bigskydrift
Thread starter- Joined
- Jan 25, 2006
- 107
Motor: Evinrude fastwin Model # 18302E Serial # E06926 1963 18 H.P. <br /><br />I replaced the impeller on this motor, during reassembly things were going together difficultly.<br />I took it back apart. Upon further examination, I noticed that the water tube grommet at the top of the impeller housing was out of place on one side and shoved down the tube. Question: when attaching the lower unit, or gear case, back to the gearcase extension, how do you line up the water tube, drive shaft and shift rods accurately? I got the shift rod and driveshaft in, but it is almost impossible to see to line up the water tube while lining up the other two parts, I have one more grommet but if I screw it up I will have to order a whole new kit...any tricks to this???? THANKS!
