1992 120hp Johnson
littlemac
Keeps filing the plugs out. Any suggestions of what might caused this?
ezeke
Re: 1992 120hp Johnson
Don't understand the question, could you explain more?
buddy_malec
your 120 is fouling plugs????? your fuel mixture is most likely the cause of this check your carbs and your mixture maybe use a small 6 gallon tank with a premix and see how it runs
Dhadley
Lets start at the begining. We assume you mean fouling out the plugs. What spark plugs are you using? How's the compression?
