25 hp sportster slipping out of gear ???
cat-n-tenn
Is there a place where i can adjust this so it will not slip out of forward gear ? someone said that there is a plate on the side of motor that you can adjust this but i thought i would ask someone to be sure. Please help . THANKS
Re: 25 hp sportster slipping out of gear ???
is it tiller or remote controled? in other words does it have a steering wheel and shifter?
OBJ
Cat....when you say slipping out of gear, is the shift handle actually moving back to neutral? <br /><br />Or, is the engine reving high and you don't gain speeed but kinda slow down?<br /><br />Or, does it feel like your hitting a log?
cat-n-tenn
yes the handle goes to neutral
OBJ
Can you feel a detent when you shift?<br /><br />Can you post a year or model number please?<br /><br />Have you checked the gear lube lately?
cat-n-tenn
my mistake the handle just stays in forward but slips back to neutral.where is the adjustment on this mechanism ? i changed the lower unit oil this week already. motor is a 1974 25 hp sportster i was told.
Paul Moir
Ah, there is no adjustment at that coupler behind the plate. But it may be installed wrong. Best to check it out.<br />The shift rods should both be completely inside that coupler. Like this:<br />
<br /><br />I belive the only thing that holds that engine in gear is the brass shift quadrant that's attached to the starboard side of the block. It also prevents you from throttling the engine too high in neutral. It should be spring loaded and free to hold the shift handle in place.<br />With the quadrant temporarily pushed off the handle, you should be able to feel neutral 'click' when you move the shifter. You may have to rotate the propshaft a bit to get it to shift. This is caused by the detent balls on the clutch dog inside the lower unit. Once you find neutral, make sure that matches the neutral quadrant on the brass bar. If it does not line up, adjustment can be made to the handle by loosening the screws that hold it to the shift handle shaft.<br /><br />If after checking all that it still pops out of gear, it could be a worn clutch dog or clutch dog & gears.<br /><br />EDIT: Something else to look out for - there should be hardly any slop at all between the shift coupler and the shift handle. Parts may be worn.
cat-n-tenn
thanks, i check it out tonite.
