friedcola2
Thread starter- Joined
- Apr 9, 2006
- 5
1995 17'Dargel Skout, 1996 88spl is leaking oil at the bottom bearing retainer at the 6 (or 8) bolt flange (not at the 4 in the middle with the o-rings). Can I remove the bearing retainer without taking the entire engine apart? I noticed that there is no gasket on this flange, what should be used to seal it?<br />2- When I ran the motor last week, water was coming from the shift rod area toward the front of the engine (under the carbs), the alarm sounded off and I shut it down. I suspect that 1 or both thermostats have frozen. Does that sound possible?
