Backfire when coming off throttle
GMCAMARO
I have 1956, Evinrude 15HP Fastwin. I just brought the engine out today for the new season, during the winter I changed the plugs, points coils and condesnsors. When I remove throttle after, giving it some throttle, but not full throttle it backfires. It runs fine at idle and full throttle. Just half throttle, any ideas?
steamboatwilly
Re: Backfire when coming off throttle
Is it in the water or out?Sounds like its out.If its out,that is normal to backfire.It wont backfire in water.Man,dont run it out of the water
GMCAMARO
Originally posted by James Williams:<br /> Is it in the water or out?Sounds like its out.If its out,that is normal to backfire.It wont backfire in water.Man,dont run it out of the water
In the water on the boat and it's been running for about 20 minutes.
walleyehed
sounds like an extreme lean midrange....she needs a carb job or opened up a bit on the high-speed.
GMCAMARO
Originally posted by walleyehed:<br /> sounds like an extreme lean midrange....she needs a carb job or opened up a bit on the high-speed.
Thank you, I shall give it a try.
Joe Reeves
(Carburetor Adjustments - Two Adjustable N/Vs) <br />(J. Reeves)<br /><br />Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns. <br /><br />Setting the high and low needle valves properly:<br /><br />NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle va /lve adjustment.<br /><br />(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, wating for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting. <br /><br />(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
walleyehed
Love it when Joe posts....leaves no questions un-answered.<br />Excellent info, Joe. :)
GMCAMARO
I did what Joe indicated. At first it ran great, then I put the knobs back on. At idle it would idle great for 1 or 2 minutes and then backfire and cut out.
Joe Reeves
If the brass jam nuts weren't tight enough, when you installed the knobs and tightened the retaining screws, the brass needle valve could have changed its position and leaned out somewhat.<br /><br />Try the adjusting proceedure again.
Is the fuel fresh?? If it is, I'd rebuild the carb and then follow Joe's directions. Could be a piece of crud in one of the passages. <br /><br />If that doesn't take care of it, at least you've eliminated a gummed up carb as a possible cause.
GMCAMARO
Originally posted by Joe Reeves:<br /> If the brass jam nuts weren't tight enough, when you installed the knobs and tightened the retaining screws, the brass needle valve could have changed its position and leaned out somewhat.<br /><br />Try the adjusting proceedure again.
Thank you for the advice I shall try that next weekend. Any thoughts on Carb cleaner added to the gas?
