water leak ?
jcarson
hi just found your site.i been doing a search and have come up with a few?. first the engine is a 82 35hp evinrude. ihad head gasket problem last year so i did a rebuild.everything was fine till last night i was fishing and the motor kept dying .do this morning i checked the plugs and the bottom one was grey first i draind the gas thought i could have gotten water in the tank. then i fired it up with the muffs attached and ran for about ten min.then i puled the head the lower cylinder was all grey and milky the top one was not as bad the head gasket had a hole right in the center between the to rings that seal the combustion chamber? the hole was not all the way through just the matriel was off on top and bottom exposing the alluminum. the head and block are flat.i read aboput another gasket that can let water in. i guess muy qustion is why would the head gasket blow again and howw can i stop it. thanks alot for all hep i really need it impuling my hair out. jared
R.Johnson
Re: water leak ?
First! Check for flatness with a known good straight edge. Make sure the head, and block surface are both clean. Use proper torgue, and tightening order. Check engine temp.
ob
Re: water leak ?
Also,remember to retorque head bolts after 20 hr runin.
jcarson
Re: water leak ?
ah ok i already looked at the head its flat as i can be,the block is fine two.the engine never got hot just ran poorly.thanks for the tips,what about that exhast gasket maby thats my culprit as the steel rings on the head gasket are still intact,thanks jared
ob
Re: water leak ?
The exhaust cover gasket/s could indeed be culprit.
jcarson
Re: water leak ?
is that the one on the side of the engine or the leg that goes into the lower unit ,jared
ob
Re: water leak ?
The one on the side of the engine is the one I was refering to.
