diggerdan17
Thread starter- Joined
- Apr 11, 2003
- 148
i need to replace my clutch dog on 35 h.p. 1980 johnson....and i know i should have one but i do not have a manual yet.i have removed the lower unit and taken the waterpump and drive shaft out. next i drained the oil and remove the shift linkage....then i removed the 2 5/16 head bolts inside where the prop attaches to....then i removed the large phillips head screw beside the lower oil drain plug.now i can not seem to slide the propshaft assembly out of the lower unit.what is the next step?i am assuming i need a slide hammer of sorts but do not want to go reefing on this assembly if i have not taken it apart properly.i put an old prop on the prop shaft and put the nut on and used that as an impromptu slide hammer but it only moves a quarter inch then stops.am i missing a step?
