I put new carburetors kits on a 1984 1 5/16ths cross flow. I also replaced all of the fuel lines. To check the lines for leaks I pumped the bulb to put some pressure in the lines. I noticed the top and bottom carbs were spilling over through the brass fittings between the throats. Is this normal? My thoughts were possibly the floats were not puttin enough pressure on the needle and seat to seal it off, or I was putting more pressure on the fuel system than the fuel pumps will. When I adjusted the float I made sure it was parallel to the body upside down, however, maybe it's just parallel and not the right height. Any thoughts would be appreciated.
