1983 Evinrude telltail
bodega
I had the impeller replaced last year. De-winterized it and ran it in a tank. The tell tail is strong when revved up but only dribbles when idling. Is this normal?
fireman57
Re: 1983 Evinrude telltail
I won't be as strong as at WFO but it should be more than a dribble. What model are you talking about? When you have idled for three or four minutes put your fingers on the head and see if you can hold them there for a long three count. If you can't you are overheating, if you can then I wouldn't worry about it but would still check it once in a while. Could be a restriction in the water jacket or your pump may be weak. Telltale might get stronger in the water when it is at the right level on the engine.
bodega
Thanks for the help. I'll stay close to the launch ramp...just in case. The model # is E10RCTC
