Proper Compression
moxieman
I have a 1962 Johnson 10 HP. What is the correct compression.<br /> <br /> Thanks, Mike
ob
Re: Proper Compression
There is no specific number.Not knowing the general condition of your engine with repsect to normal wear and any carbon buildup on ring grooves ,I'd expect numbers from 80-100 psi would be healthy ones.You also would like the cylinders to read within 10 percent of one another on compression.
