Cricket Too
- Joined
- May 14, 2003
- 1,732
Hey guys, have the above engine, and noticed at the end of last season the dash voltage gauge was reading very high, what looked like 16 or 17 volts at WOT. Never got a chance to actually check it with a voltmeter, until another problem popped up.<br /><br />Went to start it up after winter storage this year, and after putting a good charge on the battery, it would barely crank the engine, cranked good and strong for about 2 or 3 seconds and then would slow down hard and barely turn the engine, and couldn't get the engine started. Battery was brand new last year, and got a good charge this year, but it's a Deep Cycle battery and I don't usually like those.<br /><br />Took a look at the cable ends and saw a decent amount of corrosion on the battery side ends. Decided to just cut all of the + and - connections off and cut the cables back to where I saw good copper(couple of inches on each). Cut them all back to nice clean copper, put brand new connections on, with dielectric grease on the cable, and then put marine shrinkwrap over all connections. Hooked everything back up, and same problem, cranked good and hard for 2 or 3 seconds and then dies down, until it completely stops. Checked all the lugs and none of them were hot to the touch, which I've seen before with bad cables(higher resistance).<br /><br />Kept trying to start it and it finally kicked over and ran great. Decided to put a meter on the battery while it was running and it started out at about 13.5 and just kept going up. Ran the engine at about 3,000 RPM for a couple of seconds with the meter on, and it went up to about 15.3, then dropped back down at idle to about 14.6. I can only assume it goes up higher at WOT, but couldn't check that on the hose.<br /><br />So could this be charging more, due to bad cables and higher resistance, or could this be a bad regulator/rectifier and this higher charging voltage damaged the battery, which is why I now have a cranking problem? I know all of the cable ends are good, because they're brand new, and I didn't see any spots on the length of the cables that could have gotten corrosion in them, but I guess it's always a possibility. Just don't want to replace all the cables if I don't have to, since they are expensive, about $4.00 a foot and I need about 15ft of both + and -, probably $150 all said and done.<br /><br />Any hints would be a big help. I had no cranking issues last season, just noticed that high charging voltage at the end of the season, and now I have a cranking problem, with the same battery, and brand new cable ends.<br /><br />I appreciate any help, need to get on the water, weather is getting nice. Thanks again, Mike.
