peatmoss96
Thread starter- Joined
- Apr 18, 2006
- 8
I have a 1994 Johnson Venom 200 with a 4 blade Renagade prop which was rebuilt 13 months ago. The boat has been run monthly since the rebuild including proper break-in. A month ago the engine began to loose power on take off, like the boat was full of water(it wasn't). I have checked the following systems/components:<br />1.Compression 90-95 on the left bank,90-110 on the right bank(110 was sleeved on rebuild); 2. Carb settings, jets, float settings and all fuel flow locations at carbs clear, fuel filter; 3. Plug wires good, no double firing, plug gaps good, no fouled plugs; 4. Timing both idle and WOT settings good; 5. Syncronization ok; 6. No appearent cracked fuel lines or tranfer hoses. <br /><br />The power pack was replaced 2 months ago during a tune up procedure but the trigger coil tested ok (Repaired by certified mechanic). I am leaning towards a fuel restriction but the engine does not hesitate, just lacks power under load during takoff. The top end speed is not completely there but is not as noticeable, 62-67 now and 70-75 new. <br /><br />Just looking for direction on whether it may be the trigger coil, power pack or fuel(pressure, sucking air, or restriction in carbs). The motor is not popping back, missing, loading up, or surging, just no power like before. <br /><br />I enjoy working on the engine and am trying to fix it without using a boat repair service.<br /><br />Thanks for you time in advance.
