friedcola2
- Joined
- Apr 9, 2006
- 5
1996 88 spl, J88TSLEDR. When running (on the hose), engine water pressure is very low, but does come out of tale-tell, and is gushing out from under the cowling at front of engine. alarm goes off. With the engine off, I connected the hose to each of the water hoses going into the heads and water gushes from under the cowling. I removed the lower unit and connected the hose to the pipe coming from the pump to the engine, same thing again. Had head gaskets replaced last week, new thermostats installed and oil leak at crankcase fixed. Any help is appreciated.
