Re: 1967 Johnson 60 HP
Remove the distributor cap. The HT button will be obvious.... dead center of the coil.<br /><br />A spark tester can be purchased at any sutomotive parts store or......<br /><br />Spark Tester - Home Made<br />(J. Reeves)<br /> <br />A spark tester can be made with a piece of 1x4 or 1x6, drive a couple nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere.<br /><br />Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:<br /><br /><br />..........X1..........X2<br /><br />.................X..(grd)<br /><br />..........X3..........X4
