My husband and I disassembled the lower end of our 1977 Johnson Javelin 85HP OB to replace the impeller. We did this because he noticed we weren't getting a good discharge from the pee hole and the engine was getting hot. We discovered the key way had lain over and disappeared somewhere! Otherwise everything looked ok. We replaced impeller and are still barely getting any water from pee hole, it is just bubbling up, not streaming out. We feel fairly confident the tubes are lining up - but how and the heck are you sure? Is there anything else we can check. Where does the water come in? What is behind that plate on the part of the motor that faces the back of the boat? Man, it was a long day, the lower end was heavy. We struggled, and thought we had done good . . .
