Re: 1957 evinrude 35hp no-work
Ok, looks like you're doing fine here. Either the coils are set too far forward, or the armature plate on which they sit is too wobbly. Easy to check the coils, they should be nice and even with the machined face on the bosses they sit on. That is to say, surface A and Surface B should be even:<br />
<br />And here's a picture of the underside of an armature plate (sorry about the quality, it's kind of old)<br />
<br /><br />If you need some details, I can take a newer, clearer picture. <br /><br />If the reason the coils are striking the flywheel is that the armature plate is excessively loose, it's fairly easy to repair. Check out Joe Reeves' wobbly armature plate fix:<br />
http://forums.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=28;t=020981 <br /><br />Have a look at GDane's comments as well. I've had to do that too on really bad plates. With the wobble out, it'll run a lot more quietly too.
