I recently acquired my first outboard motor, an '88 Johnson 15hp short-shaft with electric start. When I purchased it, I knew it had some problems. I'm somewhat mechancal, but I'm thinking I could be in over my head at this point.<br /><br />When the motor was purchased, it had the following known problems as diagnosed by a mechanic:<br /><br />- bad power pack<br />- broken cam follower arm<br />- leaking lower unit (water in oil)<br />- bad wiring harness on starter<br /><br />I verified that one plug was not getting spark and replaced the power pack - now getting visible spark on both plugs.<br /><br />I have replaced the broken cam follower.<br /><br />I have replaced the drive shaft seals in lower unit.<br /><br />I have replaced the water pump. <br /><br />After I couldn't get it started, I took apart carb and noticed that the idle tube was cut so I have rebuilt carb and replaced that tube... still no start.<br /><br />NOTE: It is completely possible that I screwed up one of the above procedures. I think I did it right based on my Clymer manual, but like I said, this is my first outboard. <br /><br />At this point, I can not get the motor to start. I have verified that pumping primer bulb on fuel hose causes plenty of fuel to flow to carb. I'm a little skeptical on whether fuel pump is pumping enough fuel (seems like just a trickle when pull starting) but I'm thinking priming should put enough fuel in the carb to at least get her started - is that correct?<br /><br />I have tried, although not with great deal of effort, to spray WD-40 into carb to get it to start. The only sign of life I've gotten is 3-4 loud bangs (backfire?) over the course of probably 100 pulls on the starter. <br /><br />I'd be happy to try anything, but maybe I just need someone to talk me into taking it to the mechanics...<br /><br />Thanks for any help!<br /><br />Dan
