Originally posted by OBJ:<br /> Well...wrong on the black gooey stuff.....sometimes things ain't that easy....<br /><br />Probably the best thing to do is drain the gear lube and do a pressure test on the lower unit. This will tell you if you have a bad seal or oring. If it's leaking that bad, I'd hesitate to run it until I found the problem. Have you drained the gear lube to check for water intrusion?
