fastwin
seahorse44
brother in law just got a motor we are needin info in . model GG9021A serial 65X628978 . This motor aint been run since 93 . just for fun I dumped a little premix in the carb and 2 turns she started right up. He was amazed. Got to fix her up for him I guess. just wondered the horsepower , year , good points , bad ? thanks
rickdb1boat
Re: fastwin
GG-9021A= 12HP 1956 Others will know more about the oldies....
OBJ
Re: fastwin
Seahorse...where'd ya' get the model number from? Should be a tag on the port transom bracket or look on the block for a large welch plug with the model number on it. The "model" number you posted....close as I can get is a 16.2hp 1936 engine. Now that would be a find!
OBJ
Re: fastwin
OOPS! I bow to rickdb1boat....It's a Gale.<br /><br />Sorry Rick.....not that I was in doubt..... :) :)
seahorse44
Re: fastwin
obj. <br /> The serial & model number I posted came from the transom bracket tag.the tag also says montgomery ward. says Evinrude on the motor. <br /> The welch plug says 0628976 . Looks like a normal big twin except for those goat horn air intakes . looks like 2 goat horns bolted on the the carb inlet. silencers I guess lol. thanks obj<br /> Rickdb1boat, Thats what hp it looks like . anybody ever see a threaded prop shaft nut on these ? thanks
OBJ
Re: fastwin
OH yeah seahorse....some of the older J/Rudes had a thread on the end of the prop shaft so you could thread the prop nut on.....then put a cotter key through it.
seahorse44
Re: fastwin
edit: "The welch plug says 0628976 ." it says 0628978. <br /><br />Thanks obj , the nut with cotter pin is exactly what this one has . Is this thing still a gale ? <br />The cowling says 1 quart to six gallon. 24:1.<br />hottest blue fire I have ever seen on these ole buggers. Do you use the hypoid oil in the lower units ? I did in my 1958 35hp johnson . thanks
Re: fastwin
seahorse, i have a '55 15hp rude. hypiod oil, there are 2 screws(plugs) on the foot. open the bottom one then open the top one. be prepare to catch the grease. i still use the old way of refilling with the tubes. i start the top plug just enough to hold it in place, insert tub in bottom hole firmly and squeeze, air wiil escape out the top plug, fill until grease start to escape. holding tube in place tighten top plug, remove tube and quickly insert bottom plug. fuel mix is 24-1. mine start 1-2 pull everytime. will runs wot or troll all day long without a cough. there are two adjustment on the front high and low speed. it is easier to adjust on the water. get the high speed adjusted, then adjust the slow speed. mine has the goat horns. johnson/evinrude/gale are 99% identical. i got a couple of shear pins by emailing 'jodyh@sea-way.com' good luck
JB
Re: fastwin
What you have, Seahorse, is a 1956 Sea King 12HP, made by the Gale Corp, a part of OMC, for Montgomery Ward.<br /><br />Because these engines were nearly identical to JohnnyRude models the Evinrude Fastwin cover fits like the original.
seahorse44
Re: fastwin
obj,tashasdaddy,JB ,<br /> Thanks fellers . Believe I can look for my manual and parts now. 1956 Gale(seaking) huh ? dang,, guess someone put the evinrude cover on it if i catch what your all sayin . now I can search too. thanks feller . Im sure I'll be back when I get started with repairs.
seahorse44
Re: fastwin
I called NAPA about these parts and they dont show seaking brand in their books. I wonder if anyone would know where I can get the Sierra part numbers for an impeller, carb kit and fuel pump kit for this engine. Model GG9021A serial 628978 . 12 hp . montgomery ward . I also wonder if there is a johnson motor that will cross the same parts ?(seaking).appreciate any help .
seahorse44
Re: fastwin
evening folks,<br /> Just wondering If anyone knows where I can get these parts numbers for this seaking ? called everyone I know. any help is greatly appreciated .<br />need an impeller , carb kit maybe a lower unit seal kit.
Re: fastwin
if i'm not mistaken i believe you can us johnny/rude parts. i just don't know which hp. to use to fit your engine. try tcoutboard or seawaymarine. they may be able to lead you the correct way.
