Starting Trouble - Johnson Outboard
amkroenke
When I try to start it it just barely turns over and sounds like the battery is dead, but when I check the battery it is 12V and is perfectly fine. When I hook up the multimeter to the starter it's only getting about 4 volts while I'm trying to start it. I don't know much about solenoids...could that be it? maybe a bad starter?
jfm1
Re: Starting Trouble - Johnson Outboard
make sure all cable ends are clean and tight. bat.sol.starter make sure the ground is clean,
JB
Go to Engine FAQs. Do the troubleshooting in "Outboard wont start".
