I just got this outboard and I have started it twice. The first time it ran for five minutes and then I couldn't start it again. I discovered that a sparkplug cover was faulty. Once that was replaced it started again and ran for 10 minutes. Now I can't start it again...<br /><br />I changed the gas to a high octane and added the correct 50:1 ratio. I tested the plugs and they are sparking. Fuel lines look good. The throttle is suspect, not sure where it should be to start the engine. Also, not sure what the dial is on the engine? I understand the choke but is there a kill switch I should check as well?<br /><br />I'm also getting a black oily substance leaking from the exhaust hole on the back of the shaft. Could that be my problem?<br /><br />Any info would be appreciated. I'm a total amatuer with motors.
