ted655
Thread starter- Joined
- Oct 21, 2003
- 252
I would appreciate comments on prop depth.<br />I am converting from outboard to inboard. Because of shallow water operations, I can't use a typical under hull installation. My transom sets at a 12 degree angle. I am going to stibk the shaft out of the bottom of the transom, following that angle.<br />The boat is flat bottom and draws 9" of water. The prop is 20". At 12 deg. the tip of the prop is just out of the waterline. As the length gets longer the prop goes deeper into the water.<br /> Obviously I don't want a lot of shaft sticking out the stern. If I go very far with the shaft to get depth I will have to add a strut and cutless. That means a superstructure built onto the transom. UGH!<br />So... how deep into the water does a prop need to be? this is a 3 blade bronze prop on a 1 1/4" shaft.<br /> The boat is 24' X 8' heavy aluminium plate. It is diesel powered and used to push floating cabins to different areas of marsh and swamp. A slow mover not a skyboat. Any thoughts?
