turns while tubing
twa72
when you ar making 180* turns while tubing what is the best way to keep the poer up and on plane do you trim down into the turn then trim up coming out of turn?? we boat on a river so there is only so much room Thanks
MFG197
Re: turns while tubing
While tubing I like to get the rider on the same side of the wake and turn towards them this slings them accross the wake and as you continue to turn back and forth you can get a pendulum effecto going for a great ride for 180 degree turn i would trim under to help the prop hold and just keep turning.
QC
I keep my trim in (down) when pulling a tube. That works only if you can get enough speed trimmed down. What boat and power combo?<br /><br />BTW, welocme to Iboats.
twa72
It is a 89 bayliner 2.3 so it is needing all th e tricks of the trade to help out with power just ordered a hydr-foil to get it up on plane and stay there.. got it cheap and just getting all the bugs worked out.Just got the points dwelled in right going out to see how big of a difference
